Portal sometimes won't load
Hamish
Feb 19, 2015
6
Hello
I have a MEG-254 with NFPS, I have noticed that the portal won't load all of the time, I have run into instances where I would simply restart the portal or unplug the STB and the portal would load. Now that won't work. After a day or so I check the STB and it will load and works as it should. Any idea what is going on. Have I tried to use the unit during maintenance a few times over the last month? I have the unit connected via Ethernet, I have reset the Router\Modem and Switch I have even released the IP from the modem to obtain a new one. Also I have the latest FW for the MEG-254
Any feed back is appreciated.
Thank you
