Planning on setting up Avov for iptv
kovaci81
Nov 9, 2015
7
Hi
I just had a few questions. Yesterday I went to a retailer here in toronto to check out the iptv service he was offering for $20 a month. To just see picture quality and to see if it is user friendly. I didn't purchase anything. Started doing some research and came by this wonderful forum. I printed out the pdf file of how to install and set up. Seems straight forward.
I am planning on purchasing an Avov box. The donation code I plan to buy from one of the 3 websites listed for $80.
I am in Toronto and would like local channels as well. How do I do that with purchasing the donation code?
With the Avov box is it better wireless or hard wired?
Multiple tvs I assume need multiple boxes and donation codes?
Thank You
Do some more research on boxes. The price of $80 a year is very good. There are only 10 Canadian channels available as I know of. Read the list of channels available in the NFPS section. As far as wired or wireless. If you can wire it, I would say that is better. I have see some boxes do great wireless and other not. Surroundings will have a lot to do with that. Yes you need a box and sub for each TV, even in the same house.
Ok sounds good. Thank You!
Which box are you using?
I currently have the AVOV vixo2 and an OTT Box M8S. They both work with kodi equally well. The M8S does not have the stalker middle ware like the vixo 2 but any android app can be loaded onto it. I hear there is an app for stalker for it but have not found it yet. There was a reference to download the app in the Google store, but the link has be broken.
