Settings->General->Playlist:
xportal is is something like "p1.iptvprivater.tv
username and password are the same value and had 12 numbers/letters x47180G64xxx (your must have that information already)
select XC as type of playlist.
put the information carefully.
what method are you using on perfect player ?
The server URL or an m3u playlist on usb or one of kens templates ?
Or ???
have you tried a different media player?server url, I already checked xc options and the same, the channels work, VOD doesn't, I can see the movies and shows categories titles list but they don't connect, like unable
You can try to select different Decoder in Settings->Playback->Decoder
Salu2
I could test that terry66, I used HW+ since that's the only one that enable subtitles.
Thank you
How to Setup Perfect Player using my PP Settings Template File
D |
how to restore perfect player
How to Setup VLC Player with IPTV Rocket, NFPS, 66
The Players - Perfect Player
