Only red & blue light on box
cowboy
Mar 10, 2015
33
1
:confused: I have the AVOV tv online plus
Hi I am getting red and blue light on the box and will not connect, I tried re-setting as per instructions by holding re-set button and pluging power back but the blue light keeps coming back and blank screen.
Any other suggestions? :(
I do get HDMI 1080p 60Hz when the blue light comes on then this disappears and nothing , just the red and blue light on the box????
set it up to rca and use that first you maybe have the rez set wrong when boot up see if you have three buttons and hold them till you get a setup screen that may work to set it right too
Thanks for the suggestion, I tried with rca and tried re-setting but no luck.
I did get the AVOV letters on the screen now but that's all it will not go any forther.
Any other suggestions ?
