not supported error mag245
syns
May 25, 2015
66
Hey team I unplugged my Mag254 from my sony smart tv and moved it upstairs but I get a not supported error. works fine on my sony but not my insignia. it has the slash screen were it says loading but after that I get that error...
Any help is much appreciated.
The resolution may need to be adjust as well... I have moved my box before and they were capable of two different resolutions and I had to take it down to 720p before it would work. Are you getting anything at all? The red infomir screen?
TV Resolution
Yes i am getting the splash screen were it says infomir/loading..... right after that tv says "not supported"
Unplug box and restart and hold down ---..... key on the remote until you get the Blue screen menu and at the very top of the page you have the TV output options, dont forget to save & exit afterwards...;)
Sweet thanks guys. I had to put it to auto and to use system tv setting on resolutio.
one more stupid question. How do I change the city and weather in the portal, not the inner portal but the other one...
