No EPG info on British Cnannels
geevee
Jan 24, 2015
74
The USA channel info is good on EPG but all British channel info is blank.
I have not seen any posts about this issue.
Am I the only one who's MAG 254 is affected?... thks
Schedules Direct announced a change in their GBR lineup.
http://www.schedulesdirect.org/
All those who pull data from Schedules Direct have to modify their code to sync with these changes...
So Ilan are you saying the info will be coming back or not?
As of this morning (6days) the English channel info is still missing even though I rebooted the Mag.
It's nice to have the channels but without info it's very frustrating.
My subscription is due in Jan and if the info is not going to come back it means
I will need to look at another option.
Thks for the suggestion ilan, I'll try that.
I have read that if you do e-mail them they just refer you to this forum for help.
I will give it time till my subscription expires in mid Jan/18 and if the info is not there by then
I will not renew and search for a better IPTV service.
The only thing that usually works is if the money stops rolling in.
That's what usually causes changes.... thks
