No channel or guide info
Hello, how do I get the Guide and channel description to download again? I've cleared the Guide and TV cache but the descriptive info is not downloading so I do not know what is playing on the channel. When I exit and re-launch Kodi it says it's download channel and guide info but doesn't :(
depends on what pvr stalker your using...
if its latest nfps 1.0.1 then change to 72 hr epg.you will have to delete the epg_xmltv.xml from userdata/addon_data/pvr.stalker folder or wait until the next time stalker client auto refreshes the guide data.
if is older version where you enter NFPSF1,ect on the end then...
if you currently have it as NFPSF1 change it to NFPSF3
if you currently have it as NFPSF2 change it to NFPSF4
--you will have to delete the epg_xmltv.xml from userdata/addon_data/pvr.stalker folder or wait until the next time stalker client auto refreshes the guide data.--
--this instructions works well just wait to refresh updated epg.
Is there an option to manually update this info? I don't have a lot of info in the Channel or Guide section again.
I was watching a show come out to watch something else and some channels were missing the info then watched somthing else and 80% of the channels are missing the info all in a few hours.
