NFPS private purchased (help)
COMBO
Jul 25, 2015
36
Hi so since this IPTV gone private, i just made a donation and linked my MAC via the site.
Only problem now is, I need help setting it up on kodi using the G box q.
When I launch IPTV stalker I get a http error 404: not found.
I've followed generic tutorials online using port 8899. Not sure what to do next. My subscription started 30 mins ago, with 366 days activated. Plz halp!
Tried that link, and still getting errors. I even disabled PVR simple client and enabled only stalker client. That also gives an error when I try enabling in TV general settings.
Also, what is server(s) and portal(s) in donation details? Do input them somewhere in IPTV configurations?
Went to the new portal nfps portal address on my smartphone and the message reads "your stb is blocked Call the provider"
Is this why I'm getting these error messages?
It depends on where you put the url. If you put that on a browser, your will get that message. Because you are new, I'm assuming that you aren't using the STBemu, which will give you that error if your MAC is not correct (doesn't start with 00:1a:79, or has all zeros for the last six).
You will get the 404 error if you don't use the "portal.iptv*.tv" url in IPTV Stalker. A 404 error could also occur if the ISP is filtering the url with its DNS, or other network issues.
