Nexus Player - STB Emu HowTo
dixeflatline
Apr 22, 2015
13
No Root required. If you have been stuck not able to install ES Explorer from Google play store then this will work. You will need a USB OTA cable to use a wireless mouse or a blue tooth device/remote that can pair to the Nexus Player and utilize the mouse/track-pad. You can use the same principle to just about any Android machine running 4.0 or higher. Attached you will find the PDF on how to do it, I wasnt sure how long it was going to get so this way was easier. All the files you need are zipped up and can be downloaded from:
HTML:
https://infotomb.com/qv2ca.zip
or TOR
http://infotombjhy7tcrg.onion/qv2ca
Thank you
HTML:
or TOR
Thanks, I have been trying to get the STB EMU to work with the Nexus Player and your tutorial was very helpful...success!!!
