Newbie needs help - MAG256
arjun86
Nov 22, 2017
2
Yes I do
Hello All,
I am new to this forum. I recently purchased MAG256 and subscribed to an IPTV based out of USA. It was all fine on first day. I was playing around with the box did a change to Graphite them and then it all started. The box does not work at all. whenever i did factory reset, software image update via usb and all the possible ways i believe but still i get Blue screen which loads - on and off for 5 to 6 times and then get syntax error. I tried reaching out to Infomir technical support and shared the screenshots as well. i was told that its a problem with IPTV subscriber. I reached out to IPTV subscriber but no luck they direct me to the seller or manufacturer. I am just wondering if any of you can help me with this I would be grateful.
Best,
AJ
