::: New Users ::: Guide ::: How To Speed Up Your Internet :::
How To Speed Up Your Internet For IPTV
IPTV uses a very high level of bandwidth . One hour of IPTV uses a minimum of about 5 Gigabytes of bandwidth and a single video stream can use up between 1 and 20 Mbps .
Minimal requirements for IPTV is 20 Mbps .
How To Improve Streaming
Check your home’s internet connection to your Internet Service Provider (ISP) To make sure its not having issues first .
https://downdetector.com/
Note that the bandwidth that you sign up for is more of a theoretical value and not actually what you get.
Use a device connected to your home router via cable ,not WiFi for this test.
This gives you your connection’s actual speed, independent of your WiFi’s performance.
Keep in mind though that SpeedTest measures the connection to servers that are close to your location. The connection speed to the server that you intend to stream from may be slower.
https://www.speedtest.net/
The download speed is what determines how much data you are able to receive over your internet connection. Compare these numbers with the requirements for different stream qualities below to determine if your connection can handle them. Also, be sure to be well above the requirements as the distance to the server may degrade your download speed.
You may also want to run multiple tests on speedtest.net, comparing the speeds when other devices are connected to your home network and shutting them down or disconnecting them from your router. This allows you to see if your bandwidth is being used by other devices, possibly resulting in bad video playback.
Gaming consoles such as Xbox Live , PlayStation Live , Smart TVs Running Live Applications , Laptops . Anything connected to your router or combo modem/router should be turned off or disconnected for bandwidth test.
Bandwidth requirements for different video stream qualities
480p – 3 Mbps
720p – 5 Mbps
1080p – 8 Mbps
4k – 25 Mbps
How to fix streaming issues
If your connection speed is not well above the requirements for your desired stream, you may want to look at upgrading your current connection with your ISP. This will give your download speed a good boost.
Enable QoS & WMM
Extend Your WiFi Signal Range
Upgrade Your Router
2.4 GHz vs 5GHz
Optimize Your WiFi Signal
Up Your Security
Enable QoS & WMM
WMM stands for Wi-Fi Multimedia. It is a standard created to define quality of service (QoS) in Wi-Fi networks. It is a precursor to the IEEE 802.11e WLAN QoS draft standard, which is meant to improve audio, video and voice applications transmitted over Wi-Fi
Quality of service (QoS) refers to any technology that manages data traffic to reduce packet loss, latency and jitter on the network. QoS controls and manages network resources by setting priorities for specific types of data on the network.
All devices that connect to the internet through your router are continuously battling for bandwidth. One device might be browsing the web, the other streaming videos on YouTube and a third downloading software. All of these are allowed the same bandwidth (a third of the network’s total bandwidth) despite having very differing requirements. A slower download will have less of an impact than a slower stream resulting in buffering.
Many wireless routers allow you to use features that prioritize transmission of certain content types over others. The more basic QoS (Quality of Service) is usually configured manually.
Quality of Service (QoS) is a feature of routers and switches which prioritizes traffic so that more important traffic can pass first. The result is a performance improvement for critical network traffic. QoS equipment is useful with VoIP phones or in LANs with high volumes of local traffic
Default Router Login Passwords used
https://www.softwaretestinghelp.com/default-router-username-and-password-list/
::: Example :::
Even the best router’s signal range is limited. You might live in a palace or your router’s signal has to overcome many walls. Whatever the reason, your signal is too weak and your WiFi speed is adversely impacted. In this case, you have the option to place a wireless range extender between your network’s weak spot and the WiFi router. Sometimes these are also known as wireless repeaters or WiFi expanders. These devices act as intermediaries, passing on the data transmission by rebroadcasting the WiFi signal and boosting wireless coverage.
You can pick up any range extender brand, regardless of what make your router is. However, do ensure that you get one that is capable of broadcasting the same signal, i.e. do not add a 802.11n extender to a network using 802.11ac.
https://www.netspotapp.com/top-10-ways-to-boost-wifi.html
Upgrade Your Router
You should upgrade your router every couple of years. Manufacturers invest a lot of time and money to increase the performance and add new features to WiFi routers due to their popularity. The whole industry continuously works on and implements new standards for all WiFi devices to address common issues and downfalls of wireless data transmission. Your new phone might already support these new technologies but is unable to benefit from them as your router is outdated.
When looking to upgrade to a new router, make sure you pick one that meets these requirements:
Dual band support, i.e. able to broadcast on both 2.4Ghz and 5Ghz frequencies
802.11ac compatibility
WMM support to prioritize demanding applications
Strong signal output and coverage by utilizing new technologies such as beamforming
https://www.bestnetworkinghardware.com/best-home-routers/
2.4 GHz vs 5GHz
You should use the 2.4GHz band to connect devices for low bandwidth activities like browsing the Internet. On the other hand, 5GHz is the best suited for high-bandwidth devices or activities like gaming and streaming HDTV.
Bandwidth (speed): Higher bandwidth means that files will download and upload faster, and high-bandwidth applications such as streaming video will perform much smoother and faster. ... Therefore, the 5GHz with its higher bandwidth will provide much faster data connections than 2.4 GHz.
The primary differences between the 2.4 GHz and 5GHz wireless frequencies are range and bandwidth. 5GHz provides faster data rates at a shorter distance. 2.4GHz offers coverage for farther distances, but may perform at slower speeds. Range : how far your data can travel.
Tried switching to 5Ghz and switching to a less crowded channel but still facing stuttering videos?
Try these 3 tips to improve signal strength:
Router placement: No one likes the sight of a blinking wireless router. However, tucking it away in a cabinet may have a big impact on signal strength. When finding the perfect spot for your router, keep in mind that walls and other obstructions weaken coverage significantly. Also, other devices such as microwaves and other electric appliances create interference that slows down your WiFi network. Ideally, place your router in an elevated open space to maximize coverage.
Antenna positioning: Ensure your router’s external antennas are unobstructed and orient them vertically.
Replace antennas: Adding an external antenna to a wireless router that only uses internal ones is another great and cost-effective way to bump up WiFi coverage. Look for “high-gain” external antennas and consider getting a directional one This allows you to aim the signal at your actual weak spots.
Up Your Security
Finally, another thing that you should always consider, regardless of bad WiFi reception or choppy video playback, is security. Unknown to you, there might be more devices or applications using your WiFi connection than you thought.
Always protect your wireless network with a strong password using WPA-PSK. Networks using WEP password encryption are easily broken into. Not only can others use up a good chunk of your bandwidth when your network is not secure. They can also eavesdrop on your communication and sniff out passwords to websites. Don’t take any risk here and choose a password that is long and difficult to guess.
Also, install a premium anti-virus software to keep others off your devices. You don’t want your home internet connection to end up being part of a botnet that is used to carry out attacks against remote targets. If your network is experiencing inexplicably slow speed and you tried all other steps outlined in this post, do a deep scan of all your devices to ensure no viruses or other types of malware are using your bandwidth for BOTNETS.
Wired vs Wireless
A wired network uses cables to connect devices, such as laptop or desktop computers, to the Internet or another network. A wireless network allows devices to stay connected to the network but roam untethered to any wires.
An Ethernet connection delivers a consistent speed. You'll notice this fast and stable speed if you download large files. Ethernet connections are also suitable for streaming HD videos. WiFi suffers from signal interference due to many environmental factors.
Wireless Max Speed
The biggest difference between the two is speed. Under ideal conditions, 2.4 GHz Wi-Fi will support up to 450 Mbps or 600 Mbps, depending on the class of the router. 5 GHz Wi-Fi will support up to 1300 Mbps
Under ideal conditions, 2.4 GHz WiFi will support up to 450 Mbps or 600 Mbps, while 5 GHz Wi-Fi will support up to 1300 Mbps. The maximum speed dependent on what wireless standard a router supports — 802.11b, 802.11g, 802.11n, or 802.11ac.
Whether you call it Wi-Fi 6 or 802.11ax, the newer standard offers theoretical speeds of up to 10Gbps, although one of the main goals of the standard is to make Wi-Fi work better with multiple devices. There are a few fundamental changes to the way that Wi-Fi 6 works
Wired Max Speed
A 10/100 Ethernet port transmits 10 and 100 Mbps, while the maximum speed of a 10/100/1000 "Gigabit" port is 1 Gbps. Ethernet uses the highest common speed between sending and receiving devices.
How to make WiFi signal stronger
Select a Good Place for Your Router. ...
Keep Your Router Updated. ...
Get a Stronger Antenna. ...
Cut Off WiFi Leeches. ...
Buy a WiFi Repeater/ Booster/ Extender. ...
Switch to a Different WiFi Channel. ...
Control Bandwidth-Hungry Applications and Clients. ...
Use the Latest WiFi Technologies.
https://www.wikihow.com/Improve-WiFi-Reception
How to find the best WiFi Channel for your router on any OS
https://www.howtogeek.com/197268/how-to-find-the-best-wi-fi-channel-for-your-router-on-any-operating-system/
How to extend Wired Connections
A powerline adapter is an alternative to running in-wall Ethernet cables or relying on possible unstable WiFi. A powerline adapter has the ability to send your music, photo, video, and computer data over your household's existing electrical wiring just like it would over Ethernet cables
VPN Bonding
What is VPN Bonding: VPN bonding is a popular technology that is used to design WANs for multi-office enterprises. ... The technology requires cutting edge techniques to optimize around throughput and latency, to provide a bonded IP tunnel that is as fast as the sum of the WAN links being bonded.
Requirements: VPN bonding requirements assume you have access to at least two Internet connections you want to combine: WiFi, 4G / LTE, tethered phone, DSL, Cable, Satellite, etc
VPN Use : Encrypted with 256-bit AES, the VPN Bonding feature allows businesses to connect to multiple locations with military-grade protection. When an Internet connection fails, the VPN failover feature will dynamically switch traffic over to the active connections, maintaining uninterrupted VPN service.
If that's too advanced for you try Internet SLI
