Might help to know what you are using to watch IPTV. Emulator or Set top Box. This will determine what you will use for the MAC. You probably should also check the forums for what you are using. I can guarantee that you will find instructions there.
Make sure your mac start with 00:1A:78 or it wont work
C |
I need help ...please i need to know which one is my route #
C |
I need help with my order please
P |
Newbie here needing big time help!
C |
Need help with order
