need help
mmm ok ill answer this but you might want to check the thread regarding the pvr/epg and stalker. i run this via my pc so "Kodi 15.0 Isengard – Beta 1" running stalker 1.0.18, you then need to set simple pvr's settings..
this is the link for M3uURL it connects to stalkers portal h**p://localhost:8899/channels.html?portal=1 & h**p://is.gd/NFPSE goes on the 2nd tab along for the EPG. now dont activate them as you now goto settings tv and pvr clean/purge that and then guide/epg the same there then staying in setings enable the pve for kodi a window will pop up saying you need to activate a pvr program activate simple client pvr and all hould load
