Need Help With Mag 254
dalu859
Jan 10, 2016
19
Yes I do
I started up my Mag 254 and all I get is the blue background with the blue and light blue bar trying to connect. Do I need to reset my box. I see their are issues going on but I don't see anyone with the same as mine. Is there anyone out there who can help. I would appreciate.
unlink your mac, and reload the portal, see if the login/password window comes up... link your mac back to the donation and reload the portal again, and then enter your donation number for login/password and hit ok.. if you get an error, unlink and relink (or iptv reset) and then hit ok again and see if it goes through
  • Like
Reactions: crazed 9.6
Thanks for the reply Darkside . I was able to get only a handful of channels. Is this the way it is for everyone right now. Any suggestions on what to do.Should I still attempt to unlink my mac? thanks again appreciate it.
