Need help with BlueStacks, STB Emulator!
halohackz
Jun 20, 2015
5
Hello everyone, need help with my current set-up of the STB Emulator pro for Bluestacks for windows 7 Ultimate x64, First of all I have these pictures and I am currently a valid subscriber, In the first picture i'm stuck with the Blue Loading Bar, and the second picture is the URL i'm using for the Portal its self, I'm not sure what my problem is currently, I also use an external media player, MVK, but thats no good if i am not mangable to get to the Client its self, "The actual Channels", I had it set right before as it loaded on my Google Nexus Player, but the picture its self was not in the correct format ratio, I have my mac set to 00:1A:78:XX:XX:XX, but still does not work, Please help and tell me what i'm doing wrong, Someone, also I have more picture on my settings, if someone needs them, Or if there is a way you can export your Settings and upload as a zip that would be helpful to, and yes Ive tried the Iptv66 but does nothing for me as shown, Thanks!
Ok Guys I may be onto something here, if your using an android, and want to use STB PRO Emulator, I have the fix, Its more stable and a lot less buggier, First of all you need to download the .apk in from,
https://mega.nz/#!nAxl1RTK!Wn0GbxnDRJwv1fQ87Uk6IUgc_yEKzOQYlqljNBLv5Fw
Then After You Download, the PRO Version, you need to Download the x86 or Arm7 From, x86 Download link,
https://mega.nz/#!nFhCjDjD!cHDYy58D5wU8jqxcM26bBmglFnoBKhcIR57yJs_dGzI
Arm7 link
https://mega.nz/#!CQwEGDJB!-xc3Gfwxx4UWx5mEQ1AEX5ZIsUvHCLNqgY-UHe7r34U
Once you downloaded the x86 or Arm7 STB Emulator IPTV, then you must install the version you want, after installing you want to goto Profiles, then NFPS, then Serial Number, this is a generated ID, for your device, you must copy it down and save it for later, example my serial number starts with: bde9************ which should be 16 letters long, now go ahead and delete the Apk file/ IPTV STB Emulator you downloaded, and install the STB PRO Emulator from the link above, After installing, you must configure the profile to these settings, View attachment 1344 and set your Serial number to the generated one that you wrote down, and finally set your Valid MAC Address, and a extra tip in the : Menu, click Media Player and click External Media Player, Exit, then re open and click MKV player if you have it installed, it works well, Hope this helps, please leave comments below!
