Using H96 pro plusWhat boxes are you using ?
What service are you using ?
Has the MAC address from the old box been attached or linked to the donation code ?
Thank you .. succes ..If you're using STB EMU go to setting inter your URL, get the mac number from the stb emu and put it in your rocket donation reboot the app and you should be up and running
E |
i need help configuring Stalker Client again
P |
Need Help With Mac Registration
H |
need help with renewals
if you need to upgrade rocket to iptv
