Need help to configure Kodi for NFPS
bsmith999
Nov 19, 2016
17
I purchased MyGica ATV582 and configured Stalker client as following:
Mac Address: 00:1A:79:xx:yy:zz
Server address: 5.iptvprivateserver.tv
Login: 12 digits
Password: same 12 digits.
Configured-as above and enabled it.
Enabled th TV in the system settings.
I get the message not able to connect to the server. Server is available because I watch on iKS.
Also I do not get TV icon in Kodi
BSmith999
Request for Help with Kodi stalker client setup
i told you in messages that the prefix must be 00:1a:78 for the stalker applications.
You are still trying to use the 00:1a:79 prefix, which is wrong for that stalker application.
Tried with78 still the same message. Stalker client failed to connect to the server.
If you did some reading you would see that are there multiple threads with instructions that show how to setup kodi stalker. Here is one that walks you through word for on what to do. I have used it to setup multiple kodi boxes and when i end up getting the stalker failed issue its been because i did something wrong. Usually a typo. Not saying that the service is perfect but getting connected has not been a major issue for a while now. 95% of the time its user error. Double and triple check your settings reset and try to reconnect. Read the instructions thoroughly as one simple mistake can make a huge difference in outcome of the setup. From what you posted above i see your server is not listed correctly and you already know now that 78 is for kodi installs so that two mistakes with out even seeing the rest of the settings.
http://iptvtalk.net/showthread.php?...ker-Client-Setup-Instructions-for-NFPS-Server
If you still have issues post a picture of your setup so we can see if there is anything else.
Hope this helps.
Tim
  • Like
Reactions: crazed 9.6
Finally I started changing Mac. found one mac that worked, Thank you guys for sending me the valuable advise and link for the help.
EPG is the next issue, any help will be appreciated.
Thanks,
