need help starting Avov Online +
Check this out
Where to buy and what to do once you do it? Look here.
http://iptvtalk.net/showthread.php?5987-Where-to-buy-and-what-to-do-once-you-do-it-Look-here
C/P
CRAZED
-Install TV Online APP from Channel Store.
-After install complete and in that same screen, click on the RUN option.
-Next screen, highlight a Server slot and click it.
-Enter URL exactly as shown below...
NFPS - > URL: http://11.iptvprivateserver.is
Rocket -> URL: http://11.iptvrocket.tv
IKS66 -> URL: http://66.IPTV66.TV
-Use the NEXT key to exit the keypad.
-Skip down to the Connect option and click on it
-The screen will change and you'll see the Server highlighted and in that same highlighted box, off to the right side, you'll see a circle. That circle will be green when connected.
-Once green and if you then get a popup message that says something about a http header update, do not accept that, cancel it.
-You should be good to go now. Open the VOD menu
*You can also skip the RUN option and leave the Channel Store and go into your APPS and open that TV Online APP and do the connecting from there (same procedure).
