Need a little help.
Bigearl1230
Nov 2, 2015
23
I don't want to upset anyone by asking questions that have been answered elsewhere. I have looked and tried everything I can find both here and on YouTube. I am currently running a MXQ805 Ott TV BOX. I have Kofi 15.2 installed. I was using the Stalker add on. It worked fine both with Ivue and without it. I have a yearly subscription from here that I purchased right before the price increase. I was using the NPFS portal. I changed my Mac earlier today. I have the Stalker client NFPS installed. I tried to configure it like the tutsorial says. I left it on NFPS, Put the last six digits of my Mac in,changed the time zone to Easrern/USA,entered my donation number, left it on 24 hours,changed the timeout to 120 I am getting message saying addons couldn't load. Then when I go back the PVR risn't even enabled. I'm also running Dexter Pro in kodi with the Simple client. I've tried disabling them both to no avail. Now for problem #2. I am also running a STB EMULATOR outside of Kodi. I have an IPTV66 Monthly sub also from here . I started seeing the password box pop up. I used my donation number for both fields. It says error. I even upgraded to 7.11 still getting a error message. I tried to change my Mac address but every time I clicked on submit it take me to the resellers sign in page. Does this mean that the Mac is already in use or something else? Any help will be Greatly appreciated! !
There is on-going server maintenance in progress, so connecting has been a challenge today. Also, the servers changed the method to access the donation checkers where you changed your mac. When things settle down a bit, start with just resetting to a mac that you know worked before, and getting the Client NFPS working.
Basically the same advice for the the STB Emu, the connection problems may make fixing things hard, but when thing settle down, do the things you did before to get it going.
The STB Emu will ask for your route number when it allows you to connect as your login/password.
