My Review Dreamlink T1 plus
Opening the box i found it was very nicely packed
I like the compact size
Found it very easy to set up
You can be up and running and in a few minutes
The T1 plus is very fast
The epg guide works great on live TV
The google play is a nice option
In my opinion one of the nicest boxes I've used so far
I was very happy that Kodi 17 was added to the market about 20 minutes after i started working on the setup
Thought Kodi 17 would not work with the T1 plus because of the android ver T1 is using .?
It's a fork. It appears as EBox MC when it is loaded, and can run on Android 4.4. It does show itself as a version 17, and has the interface features of Kodi 17, less the 3rd party add-on check. I prefer FTMC which is based on Kodi 16.1 but has the ability to play https streams.
Is the EBox MC based on SPMC ?
I don't think so. Like I said, it does act more like Kodi 17, it also has the default skins for Kodi 17. It may be a version of Kodi 17 that has downgraded or modified code to enable it to be run on Android 4.4. The worst feature of Kodi 17, the 3rd party check, does appear to be removed or disabled, and there is no toggle to disable Live TV/PVR globally, like Kodi 17.
