connect the RCA jacks from Mega to the TV, leave the HDMI connected.
In the TV menus, change the input so it's seeing them RCA connections. Now into the resolution menu and change that to 1080 and exit out...
Then back to input selection and change it back to the HDMI connection input.
Check results.
Plug in the RCA cables to the box and to the TV, change the source to where you plugged the RCA cables on your TV now once you turn on the MAG you have to quickly press the Menu key to get into the bios, no switch the connection to NTSC 1080p and then go down to save and exit with the right error on the remote follow instructions and you should be good to go on the HDMI.
1)connect rca cable and hdmi
2)goto settings/setup, change video resoution to 1080
3)iptv will reboot, tkae rca cable out and switch to hdmi mode
note - in rca cable, the colours are messed up (black and white only) i dont think you can actually watch it on that.
