Moded Premium Tivimate apk for you guys (enjoy)
I have and tried to manually update but no and setting is to update daily, no worry though i will reinstall and see
smarters pro i have to manualy up date too i know i am answering my own ???? noooo they have a fault too google say so
other players are fine
This player works good but after a week or so it does not update the EPG
It doesn't matter what you do. So I reinstalled it and all was good for another week
now it did it again
Is it my set up?
I've got the same problem. Backup, clear data and restore doesn't work either. Will try uninstall and reinstall. It's annoying to have to do that all the time. Is there any other work around?
tivimate 2.8.0 was the last mod version that CMist released, it has 2 bugs which do not allow the update of the guide and channels, I said this in many posts.
the versions with the option for mac do not have a mod since the language of the apk changed
but there are a few players that work excellent on any android, be it the $20.00 usd or the $500.00 usd
Tivimate 5.1.0 premium mod FREE
This is a hacked version of Tivimate 5.1.0. It is hardcoded to a number of servers, but probably not your server, and you will not be able to directly add your server to this app. However, if you have tivimate 2.8.0 mod installed, this will upgrade that app with all server settings!!!!! Also if you create a backup file in 2.8.0 mod, you can restore the backup into this app. Definitely works with xtream codes, don't know if it works with m3u or emu. Just paste link to browser and replace xx with tt
hxxps://archive.org/download/tivi-mate-5.1.0/TiviMate_5.1.0.apk
