Mini 150M USB WiFi Wireless Adapter LAN Card 802.11n/g/b with 2dbi
ishtiak90
Mar 15, 2015
3
Hi, I bought this wifi adapter off ebay, but I can't get it to work with my mag 254. When I go to settings>system settings>network>wireless> it says "wifi not connected".
Does anyone know if it's compatible with mag 254?
Anyone here own this adapter ? and is working for them?
Please see the attached pic for the adapter info. Thank you View attachment 445
Im using the exact same one on my mag254. Works fine. did you enter your ssid and password of your router for the connection ?
I use one on my jynxbox also cause the jynxbox ones suck.
keep at it, it works.
I have 5 of these adapters and none of them are working. So I bought a Samsung adapter today to verify and it's working fine!
I think mag 254 is not compatible with this adapter because it says " wifi adapter not connected" When I go to settings>system settings>network>wireless>
Happy you got it working. Its compatable cause mine has worked for months.Haven't had an issue with mine but that could change at any time. Was cheap. Thanks for your info.:)
this is the one I use.
HTML:
http://www.ebay.com/itm/802-11n-g-b-150Mbps-Mini-USB-WiFi-Wireless-Adapter-Network-LAN-Card-w-Antenna-/200755616792?pt=LH_DefaultDomain_0&hash=item2ebdf79c18
I bought a wifi adapter off amazon that claimed it worked with the Mag and I had trouble getting it to connect. I first had to disconnect the cat5 cable and go to the inner portal where there was a place to set the adapter up. Could not set it up in stalker but after setting it up on the inner portal it worked in the stalker portals.
There is a lot of ebay suppliers selling WiFi adapters they say are rt5730 but they are in actuality ralink 8188 chipset and look identical to the 5730's and they wont work in the mag If you notice some sellars are finally changing the text of their ad
