mag254 sound control
check that the VOLUME on the STB is 100% ,and then program your remote to use the TV VOLUME
dont cut the STB volume ..
I'll give that a try and report back
Does it happen when you change channels? If so HD channels have lower volume than digital channels.
It happens on any channel that I watch I'll turn the volume up a little and it will be OK for a bit then the volume will go higher so I turn it down and it will be OK for a bit and then the volume will go lower. Its like this constantly drives me crazy sometimes lol .
