mag 256 bios menu Help
filmguy695
Oct 19, 2015
39
My box seems to be frozen on the infor screen it simply wont load. I have done the hold menu button down while plugging in the unit there is no change. I changed it from nand to dchp and now this is the result. should I just throw it away or can someone help me ?thx for any and all help
I doubt you should throw it away... unless you precive our world as a throw away world, as many do.
Did you try running it over with a truck ?
Try the same box on another TV
Choose Def settings right arrow hit ok
Set Tv settings to auto
For Graphics set to tv settings
For boot mode set to Nand 2 Exit and save will boot and then go to factory settings and install all your settings.
Any more questions just post them .
