I have two Mag 254 but one will only load when I set the video to SD mode. If I use any HD mode, it will not load.
Any assistance?
Any assistance?
Server is down right now jimmy, may want to wait till it's up to troubleshoot
NP jimmy.
Take it that it worked again after the server came back?
make sure the tv is set to 1080p and set the box to that too
Did that. I have two Mag 254. The other works fine. But when I put the exact settings in the other in this that is having the issue, The HDMI port seems not to work. It only works on NTSC (480i)
You need to go into settings and change from comp. to hdml then should work
Jimmy are both boxes updated to the latest version. are the configurements identical?
Jimmy try switching HDMI cables with the unit that works...
the Mag seems to prefer the ver 1.4 HDMI
K |
mag 254 will not turn on
C |
Mag254 will not turn on after being off over night
C |
mag254 will not connect
D |
Will an HDMI splitter work on the Mag 254?
