just trying to reset mag 254 from bios since I cant get to the others setting.
when rebooting it loads the screen with he logo for a few seconds then it goes
black
Unplug from power. Press and hold the 3 dots w/3 lines boton on top of the + volume while you plug the power back. That will get you to the Bios menu. Change DCHP to NAND2. Save and Exit. Will reboot the box. Your red infomir logo will be gone but the box will be back alive
