• BuzzTV 4000
    BuzzTV 4500
    BuzzTV 4900
    BuzzTV 5000
    BuzzTV VidSticks
    BuzzTV Essentials
    Sticky Threads can be shared among the BuzzTV models.
    Of course some things would be different, such as the specs and etc, but the options and setups should be the same in most cases and similar in other cases.
mac address to m2u help
there few thing you can do.
since you remove the Mac address then go to server settings and move to XC api option instead of Mac or m3u.
enter url, username and password. your donation code is your username and password and its case sensitive.
now connect and you should eb good.
if you want to enter m3u option then go to server settings, you will see local IP address on top right corner. now enter that address on your computer and you should be able to remotely login and copy/past from your pc browser. once add then connect using m3u option.
its very easy.
