Does the M8 4K have wireless capabilities?
Thank you
set up what?Thank you
Do you know where I could get set up instructions?
go to settings/wifi and select what you want to connect toThe wireless set up portion of the M8
Thanks for the help on this will try both suggestions.
glad to hear that.Thanks Guys
Got it working no problem, although a little slower with the WiFi connection compared to wired.
