Log in problems
I'm not sure where to post this so direct this to the right place. For the past month or so I've had to log in, to post or reply, more often then before. Each time I log in I see the thank you for logging in page but sometimes it opens up and I'm not logged in. I repeat the process sometimes more than once. Also I sometimes get bumped off after logging in minutes after I've been on the site. So maybe one of the moderators can check it out for me.
Thanks,
hapy
Just to post this message I had to log in 2 more times. I just logged in again to add this line.
In the Mean-time, check the Box = Remember Me until it gets straightened out...! You will bee able to Go Away and Come Back later (Unless You Close Your Browser and turn Off Your Device used to visit IPTVTalk)... Then You will have to Start All over again with the Sign-in Process...! Don't click the Forgot Password as You will get an "Invalid.... Response"...
Been having to Wait for the page to Load after getting onto the site quite frequently lately and just a few minutes ago, got this :
"What happened?
The initial connection between Cloudflare's network and the origin web server timed out. As a result, the web page can not be displayed."
Finally had to click on "Open in New Tab" to get in...!
Even gets slow when going to New Posts and trying to Open Them Up...!!!
No Problems going to and getting into Other Sites that I do on a Daily Basis...!!! Have Done Scans on Me End and Nothing to bee Found...!! Does the Site Now have "Tracking Malware"...?!?
After clicking "Post Quick Reply" below, this pops up :
Error 522 Ray ID: 5c764f2e7da0d4ed • 2020-08-23 16:46:53 UTC
Connection timed out
The RAYID message is probably related to a violation of a firewall rule on some part of the chain of connections the ID is a MAC link address for whichever of the paths the message originates from. Sometimes if you use a VPN the server for the link will see it as a invalid link and if it pings as an anonymous or unknown server it will not pass any data the timeout is probably related to the time it took to ping multiple times and didn't receive a satisfactory response. Most of the time if you don't get the same path retrying will connect you to what you want, BUT if one of your dedicated servers has changed their firewall, or access settings you may have to go a different route.
Good to hear that my friend, seems like every time I see a truck from my provider around we have trouble for a day or two, anytime they make changes to ours the modem stays yellow lit for quite a while. With the state of internet surveillance these days, I just hope that the worlds traffic will get more open and free but it seems like it is becoming less and less private while it becomes more expensive to use.
FF has a "Private Browser" that 4me uses when doing any $ Transfers and so far having Great Results...! When searching on a regular Browser the Junk email folder fills up... After using the Private Browser Junk email is Empty...!
4me has asked if the New Internet Explorer was Safe but, But, BUTT, No replies in the Browser Section of the Forums...!!!
Stay Safe Me Friends, Only You can Protect Yourself..!!!
As far as I know MS replaced IE with Edge, I have to use Edge to connect with my provider, I get a message that IE is no longer supported. I had to go through and disable many layers of ad, and google spy crap in it to use it. It really pisses me off that these companies used OUR money to make millions while our TV used to be free, we used to get a complete program that we could do clerical work with and photo retouching and splicing. movie editing, ETC and AD FREE browsing. NOW nothing is complete, anything you get from any large software company has to use a cloud storage and their mainframe to do your work, any system that has been built since the 2000 debacle wont run any of the good older programs like the ones I had on windows 3.1. They have become super wealthy using OUR tax money all the while digging us into a spy, slave, theft network that requires us to give more and more of our money just to get what we used to get free of charge. Seems that TRUMPS first act if he is reelected is to put a stop to their extortion. Too much money there though they can buy off any judge.
