Lock and Unlock channels
crazed 9.6
Transparent Wall Technician
Oct 31, 2014
16,680
457
83
As per our newest update release notes..
-updated the locked channels and favorites menu functions. Now you can unlock channels more easily as well.
It is very easy and here's how.....
Open your LiveTV
While viewing a channel on full screen, depress the Blue button on your RCU and the channel will be locked, if you then depress the OK button which takes you to Channel List View, you will see the Lock icon beside that channel..
Depress OK again to go back to channel view. If you now change the channel and come back to it, you will then need to enter 0000 as the password (unless you have previously changed that password to something else).
While still in Channel Viewing and with that same channel on screen, depress the blue button again and that channel will now be unlocked.
You can also do this same thing while in the Detailed Channel List View.
But in this menu you would use the Red button and not the Blue one.
