loading firmware
crazed 9.6
Transparent Wall Technician
Oct 31, 2014
16,680
457
83
check the thread linked below
http://iptvtalk.net/showthread.php?30535-New-r19-firmware-update-discussion-thread
Post # 4 on that thread will show you how.
'Go to Inner Portal' option.
Then into the next Settings tab you will see there.
Then in there ensue it shows...
Autoupdate : With Confirmation
Update beta versions = On
Then use the green button on remote (update Manually).
Then with New Version slot highlighted, use the bottom left hand button on your remote (as pictured on that New Version slot). That function will bring up any and all versions available.
If not, then exit back to where the menu screen shows the 'Select a portal for loading'
It gives you chooses of Embedded Portal and your server URL portal and the System settings Portal
Go into Settings.
Then scroll the next screen down till you see the Software Update option.
Open that and it should show ..
Update Method : HTTP
URL : http://mag.infmir.com.ua/254/r2/imageupdate
New URL : http://update.infomir.com/mag/254/imageupdate
Then OK to verify....
Then Exit back out and into Embedded Portal and into Settings and back into Software autoupdate and the green button again.
