KODI addons
1944
Electromagnetic Wrangler Extraordinaire
Jan 15, 2015
648
3
I have a T95Q with KODI 18.8 installed.
I have about 6 add-ons on the box and starting
today almost every movie I try to watch
on all of the add-ons I get the message
no stream avable anybody know what
happened???????
Make sure you have 2 addons installed ...
[h=3]How to Enable RTMP in Kodi (VideoPlayer InputStream Client)[/h]
  1. From the Kodi main menu, click on Addons. If you are using a skin or build, this is probably found by going to Settings > Add-ons.
  2. Click on My Add-ons and then go into the VideoPlayer InputStream section.
  3. Click on the RTMP Input option and click on Enable.
  4. As well if it isn’t already, click on InputStream Adaptive and click Enable.
  5. That’s it! Try to enable RTMP in Kodi and see if this fixes your Kodi streaming issues.
kodi addons
I went to the inputstream adaptive section and this is what I have 2.4.5 by peak3d
min. bandwidth bit/s 0
max. bandwidth bit/s o
max. resolution general decoder max
max. resolution secure decoder max
stream selection auto
override HDCP status off
ignore display resolution
decrypt path special://xbmcbin addons
media
That didn't work I added to my post to just what I have on my screen.
None of the add-ons will download the movies or TV shows never had
this problem before.
This is all new I deleted KODI and started over new KODI 18.8 and new
addons. How do I get the add-ons to download??????
I uninstalled my KODI to start over brand new.
I downloaded KODI 18.8 and one add-on &
I can get it to download but with the message
no stream available on the movies & TV--what the hell is going on??
