jittery picture quality issues
I'm running iptv stalker client on a firetvstick and I have the same problem. The annoying thing is that it seems happening only in low quality channels while the ones in HD are super smooth.
You can try turning off video acceleration to see what effect it has? It often reduces "jitteriness" appreciably.
I tried to do that and the sd channels get a little better but still almost unwatchable but switching off the acceleration makes the HD channels even worst.
I'm trying to get to work the stb emulator to see if it works better but I keep getting the message "connection error" ona blue screen.
One of my devices is a Fire Stick. I don't have any issues with the channels when using it, so it is hard for me to put a finger on your issue. The Fire Stick is a low memory device, so free up as much memory/cache as you can. Also, you can look into tweaking the advanced video settings. Some people claim it performs miracles while others report little if any success. You can Google "advanced video settings kodi" to find information on the topic. Make sure your tweaks are intended for the Fire Stick and not for a device with more RAM.
