ivuetv guide issues
assassin
Sep 1, 2015
1
You bet
Need help with my guide,it works with most link. However when it comes to ESPNU and NFL network and other links it says "unauthorized".
If I go directly to the Iptvstalker and select "all",click the exact same files it work like magic without any issues.
Need help,it's a little frustrating!!!!
try this trick go directly to the Iptvstalker and select "all then right click on channel to save it to favorites do this for the channels you are having issues with then go back to ivue again right click on the problem channel click on remove stream then click on choose stream and point it to favorites then click on save 9 times out of ten that is the work around hope this helps
