IVUE TV GUIDE "MAC" erro and IPTV STALKER updates stops it working
markie156
Sep 16, 2015
1
so i wanted to see if IVUE GUIDE would work again but it coming up with a "MAC" error now?
also when IPTV app updates its stops me from watching channels, in the options is takes the away the ability to send mac address (its not there)
I was running 1.0.20 in stalker in kodi and the ivue guide. I did register the proper mac address in rocket for kodi and was using ivue fine without any problems. I noticed that the stalker took an update to the 19 and it still is working. Ivue did some updates to the wizard which gave ivue for the stalker guide 289 channels. I am not running the stalker client but the simple client. I am doing this through the avov vixo 2 and hardly ever see a need for not using KODI. You can find the kodi mac address under system, information, on second page. Just change the first three bytes to 00:1A:78 and register with your service.
The "mac" error means that you need to use the 9.0.19 version of IPTV Stalker, as iVue no longer will send your MAC and serial number to IPTV Stalker. The serial number is not required on the supported servers, so 9.0.19 does not give you that option. You will need to configure the IPTV Stalker with your linked MAC. See the IPTV Stalker forum in the Kodi Discussion area for instructions on how to do this.
