issues with VOD
i having issue with the video club none of the movies are not playing to the end they play to a mention and then stop anyone else having this issue with the VOD
LOL, ...Double Negative!
"None" of the Movies, are "Not" playing to the end.
So you really mean, ...All of the Movies, Are playing to the end?
Probably not!
Sorry, I know what you mean.
This happens occasionally on many selections.
If it freeze's, just click "Pause", wait a few minutes, then click "Play".
If it still does not continue, try forwarding a couple minutes, then try it.
If it does not play there, then go back 5 minutes or so, to a point that it did play.
If it does not play from there, then the VOD Server for that Portal, is offline for some unknown reason.
I'm having the same issue, the movie begin and after 10 minutes it fezzes and stop, I notice that it does that during prime time peak hours from 6PM-10-PM. It seems that outside that time frame it works. The problem is that due to work schedule like most people I can see TV just during that time.
I can play the all movies but I can't able to see the Image of the movie on the right side (Movie logo). It was used to be able to see but I don't know how stop I try to reset whole Mag 254 but it still same
