Issue with MAG 254
Good Day,
Within the last week, I noticed an issue with the MAG 254. On occasions when I put in a channel number (any channel number) directly from the remote, or I use the channel up or down button, the unit fails to respond and go to that particular channel. If you press the home button on the remote, you will see "loading" at the bottom of the screen with the channel list. After about 2 minutes, the channel will eventually change. Anyone experiencing a similar problem, what might be the cause, and how can it be fixed? Thanks for your input.
