is thare a way to view guid online?
I don't understand your situation? Is the PVR client working and you can't get the guide to work or are both the client PVR and guide not working?
Anyway, if you want to use iVue guide, download the latest modified version of IPTV Stalker, version 9.0.21. It is available from the first article in the following thread...
http://iptvtalk.net/showthread.php?...nd-serial-number-enabled&highlight=ivue+guide
Once it is configured and iVue guide is installed, they'll work in tandem.
if you guide keeps crashing with pvr.stalker.. . it simple. use the channel manager and disable all the channels you do not need.. ill upload a tv29.db later that has all non english channels disabled.
i have set up severall fire tv sticks... did not have the same issue as you... i am assuming y ou are using some kind of modified version of kodi, or addon wizard to take the lazy mans approach at setting up kodi.. there is a reason i suggest against this in the epg.ninja thread, because this happens.....
i was going to look into an online viewer for the guuide... none of the web based xmltv viewers i found worked... if you find one that actually works, let me know and ill host it on the site..
i dont know how to explain it but the ivue guide works but it dousnt show all the iptv channels or in order and when you click on it only about 20% actually launch iptv i have stalker cliant 0.8.4 and iptv stalker 9.0.21 all set up from what i can tell right even though it seems the guides leave out setting in them or refer to others that are confusing in some ways due to seems like thay are older versions and dont work the same or look the same. wish someone made a guide for setup from beginning to end without links to other guides that sometimes dont work.
