J jlbwcu New member May 24, 2015 22 0 0 yes i do Mar 12, 2018 #1 Mar 12, 2018 #1 or will the STB get blocked even with USA servers? or should i just use a dedicated vpn router and change the donation to the country I am using for the router? thanks
Ryu Bad Street Fighter Kingdom Protector Knight Order Fire Rescue 2K 10 Years 1K Days Nov 23, 2014 4,954 288 83 Acquiring Signal Mar 12, 2018 #2 Mar 12, 2018 #2 yup, vpn not allowed buddy.
J jlbwcu New member May 24, 2015 22 0 0 yes i do Mar 13, 2018 #3 Mar 13, 2018 #3 okay thanks one more question can i use a VPN with a MAG Box then? or is that blocked too?
crazed 9.6 Transparent Wall Technician Knight Order Oct 31, 2014 16,675 441 83 Mar 13, 2018 #4 Mar 13, 2018 #4 VPN will work but the service does not allow VPNs due to the IP changes that come with VPNs. If you use a VPN and the service notices, then you may run the risk of getting your code banned
J jlbwcu New member May 24, 2015 22 0 0 yes i do Mar 13, 2018 #5 Mar 13, 2018 #5 thanks all! not the info i was expecting, but i can work with it.
