Iptvsubs issues
babak0122
Aug 8, 2016
1
yes I do
hi, i had iptv stalker and privarpteserver before and they worked fine with the emulator, however with my current subscription with xxxxxxxxx , I have problems with setting and favorite , in setting there is no option as portal so i can't change it and when you add channels to favorit you won't be able to remove them and when you move the channels up and down it won't be saved and it goes back to it's original spot or number, help would be appreciated.
