Iptv stalker help
Depending on where you made your donation to go to whichever link is relevant:
NFPS: https://papiao.is/main/search_nfps
[B]or[/B]
Rocket: https://papiao.is/main/search_rocket/
[B]or[/B]
IPTV66: https://iks66.tv/main/search
Enter your route/donation number (your route number is at the bottom of your email under Username & Password), complete captcha challenge & search. Then change MAC (use format 00:1A:78:XX:XX:XX) You can replace the X's with the last six digits of your android box, you can change a digit or two or you can generate a new MAC by going here:
  http://www.miniwebtool.com/mac-address-generator/
In the 'MAC address prefix' field type 00:1A:78
In the 'MAC address format' field click the dropdown arrow & choose the second option (the one with the colons)
Click 'Generate MAC Address'
Use that as your MAC address when linking to your route/donation. If you get an error just change a digit or two until it's accepted.
Before you do that can I just ask you what server URL you're using in the portal settings?
Depending on your donation the server URL to use in the portal settings should one of the following:
Url: http://portal.iptvprivateserver.tv
or
Url: http://portal.iptvrocket.tv
or
Url: http://mw1.iptv66.tv
