Iptv Help
sandocan1
Jun 30, 2017
2
Hi all and thank you in advance for your help ..
i am new with this Iptv really do not now nothing.
i just buy a new Dreamlink T2 and i do have a password etc from rocketserver
I got no idea how to set up this box to make it work
its any step by step info I can use .
Thank you ..
The T1 Plus tutorial would be same as the T2
The first link posted below will show the popular set-up method, and the second link will show a couple alternative methods.
Cluck on the link...
http://iptvtalk.net/showthread.php?29276-Dreamlink-T1-Plus-Server-Set-up-with-MAC-attached
http://iptvtalk.net/showthread.php?...s-amp-m3u-Playlists-USB-URL-or-Portal-methods
check the next link for rocket website login instructions, so you can attach your Dreamlink's MAC to your rocket code.
http://iptvtalk.net/showthread.php?24280-log-in-credentials-for-iptvrocket
check the next link for rocket Playlist URL or m3u hard copy of the playlist
http://iptvtalk.net/showthread.php?27179-How-to-get-a-Rocket-Playlist
