i need help
dishdude2
Nov 25, 2014
8
hi guys
every once a while everyone needs some help i think this time my turn...
i have the jynxbox m6 and i did install kodi helix
now on the splash screen still says XBMC short cut
now how can i replace that with kodi short cut
any help would be greatfull
Seems the jynx isn't being used by the helping members on the forum.
It happens sometimes.
On other android devices there is usually a list of icons you use with a + beside them.
If so, click that plus and select what you want visible on that list.
Exit out when finished
Just a hunch, may be setup different
thanks for your replay Bio
yes also i know that but just this box i am having a problem locating info how to replace the short cut from splash screen
thanks any way i will keep looking
problem with Jynx is there is no support, if you say anything against the support on their own support website you get banned, hence the support is very limited. They banned many people inc people who contribute greatly here and other forums.
Total shot in the dark here. Do you have an app drawer? Is the icon in the app drawer? If so hook up a mouse and then drag the icon to your home screen. On most android based boxes its just a custom launcher. If I had to guess this should work.
where do you look for the app drawer ?? if you talking about front screen with plus sign on jynxbox dont have it atleast i didnt see any there
How to Remove Icons from the Android Home Screen
http://www.wikihow.com/Remove-Icons-from-the-Android-Home-Screen
You have to attach any mouse to the box.
Good luck
A few years back I use to sell this product and stopped because of the lack of support, but over time I did manage to get in touch with a tech. This may help you get in touch with JYNXBOX support. The techs name was Steven at E-Mail *****.
He was probably the only person there that I ever dealt with that had a lick of sense. I hope this helps you but be ready to wait it takes them forever to reply. Good luck if you get an answer please let everyone know how to do it.
