Followed the video (I am on NFPS), and got this error on VLC:
VLC unable to open the MRL.
Are there any links on the Forum where the playlist can be copied from for the public?
http://p1.iptvSERVERNAME.tv:80/get.php?username=xxxxx&password=xxxxx&type=m3u_plus&output=ts
Try this:
Code:http://p1.iptvSERVERNAME.tv:80/get.php?username=xxxxx&password=xxxxx&type=m3u_plus&output=ts
replacing SERVERNAME with rocket or privateserver, and the xxxxx with your donation/rocket number. If on 66, s1.iptv66.tv is the right server, xxxxx is your route number.
If it doesn't work on VLC, you may need to null your MAC on the checker.
How to Setup Perfect Player using my PP Settings Template File
How to fix Dolby Atmos in VLC
P |
How to play Kodi streams in VLC Media Player
Playlist M3U URLs / Playlist M3U files - How to
