how to set-up a wireless bridge 254
Nadman
Feb 12, 2015
38
I have a mag 254, and I used the Mag 254 set-Up Guide that was posted with no problem, on Item #3 It said: For wireless you need an usb adapter so we won't go into that now.
Well I have my adapter, but I can't find a post that has the directions to set it up. Would appreciate any help...
Nanman
You insert adapter in rear usb!! In advanced setting set to wireless!! In network, in wireless select your router then add your password and reboot.
When in network info check that wireless is UP!!
