How to program Dreamlink T1 Remote Control
Status
Not open for further replies.
How to program (TV) or (SOURCE) keys
1. Press and hold [TV] for 5 seconds. The LED goes from blinking to solid and STB Remote Control Unit will enter Learning Mode.
2. Press the Key to be programmed on T1 plus Remote Control Unit. LED begins blinking slowly.The key is now ready to accept programming.
3. Aim the TV Remote Control Unit towards the front of the Dreamlink T1plus Remote Control Unit (the distance must be less than 3cm).Press the button on the TV Remote control. If the T1 plus Remote Control is programmed correctly, the LED will flash 3 times.
4. Repeat step 2-3 for other keys.5. Exit Learning Mode by pressing any other button on the Dreamlink T1 Plus Remote Control. LED turns off.
Status
