How to Fix "Bad or Missing Serial Number" Issue (This worked for Me)
bloodhod
Jul 18, 2015
96
Here How I Get fixed this issue
Go to IPTV Stalker Settings
Then Select Send Serial Number Option
Press OK... All done... No need to add any Serial Number. Just check that Send Serial Number Check Box.
Give a feedback if this worked...
that option isnt in version 9.0.19 so we cant do that , thanks the heads up tho
Oh The only way As I see is Adding Send Serial Number Option... Worked for me. Now have no any problems. I unchecked that option and it getting that error again... So only way is is Adding Send Serial Number Option. After checked that Option IPTV Working without any problems...
