how i got all my firesticks and boxes running in kodi (instructions)
rickypabon
Feb 22, 2016
5
Note: First change your mac then reset iptv.Then go to kodi and follow this steps this wont give you epg for now. And must have live tv disable
Stalker client pvr (not nfps)
1. In general settings activate portal 3 (IPTV66)
2.Connection time out ....12
3. Then go to portal 3 and in the first space add your new MAC.
4.Address: http://mw1.iptv66.tv/stalker_portal/c/index.html
5.User and password put your rout number in both
6.xbml prefer
7. In token put 4 numbers (1234)
8. Serial numer put 12 Digits and a letter exp : (374268537961A)
9. IN ID pUT 12 Digits and a letter exp : (124753269101B) must be different to the one above
10. In ID2 put 12 Digits and a letter exp : (127368542786D) Must be different to both numbers above
11. In Signature put a name it can be your name
Then click ok
Go to live tv clear data at least 3 times then enable live ... if it says unable to load channels wait like a minute and enable again live tv
I hope this helps
Thanks rickypabon for the info. I've been struggling to make both my firetv and my fire stick work with no sucess. I'll try it tonight and let you know.
Thank you!
6.xbml prefer
Then click ok
I hope this helps
