how change info for NFPS stb emulater
montysaad
Jul 18, 2015
1
I use NFPS stb emulate and not alowed me to go and change 11.iptvrrivateserver to 5.iptvprivateserver
is there any way can be done or reset all information
thanks
You need to go to settings then profile... From there you will see the portal addy your currently using that needs to be changed. I'm using the pro version but I dont think that should matter
This is the NFPS version and it will not give you the option to change the Portal URL. It's greyed out. I have the pro version also and it will not load after I put in the password. I got trouble all around lol
